Activity Forums Adobe Premiere Pro Grading
  • Posted by Vince Machard on May 5, 2022 at 11:16 am
    Hi Folks,
    I need some advice, I have footage that is not shot in a LOG format and find it very limiting trying to grade just from the footage given, how does one replicate/grade footage, so that I can use a LUT if said footage is not in LOG? Is this possible, is there a trick to doing so?
    Hope this makes sense.
    TIA
    Vince Machard replied 4 years, 4 months ago 2 Members · 2 Replies
  • Chris Wright
    May 5, 2022 at 4:10 pm
    you could try the cineon effect (linear to log). or maybe change the color management. or try a layer set as mode ‘multiply’ in curves.
    also, your gamut is going to be clumped into a small area, so play with sat v sat.
  • Vince Machard
    May 6, 2022 at 8:46 am
    Hi Chris,
    Thanks Mate will try it out and revert.
