Activity › Forums › Zaxwerks › gradient artifacts problem…
  • gradient artifacts problem…
    Posted by Jose Luis martinat on June 16, 2010 at 11:19 am
    Hello,
    Im working for with a project with proanimator via AE.My animation is pretty simple just a blue 3D square moving around. I get this pretty anoying circular lines on the faces of the square. It looks like i put a bad gradient color effect. It has like noticable lines going down it, like thick lines. You can see it in the picture I´m ataching
    My composition settings are PAL/DV sqauere pixels. Pixel aspect ratio: square pixel. I would aprreciate any kind of help. I get this porblem all the time, even on the preview in AE and when I render it as an animation in hirh quality. Looks pretty bad when playing on projector.
    best regards,
    Jose Luis
    Edward Wu replied 16 years, 3 months ago 2 Members · 1 Reply
  • Edward Wu
    June 17, 2010 at 12:23 am
    Hi Jose,
    I don’t see your attachment. Please send the picture to me at ed@zaxwerks.com
    Also, if you attach your After Effects project, I can take a look at your project setup.
    Thanks.
    Edward
