Activity › Forums › Adobe Illustrator › Gradient applied in overlapping objects
  • Vincent Rosati
    August 8, 2015 at 7:47 pm
    Right now you have 3 objects.
    Duplicate the objects, to the side, so you have 6 objects – Two sets of 3 objects.
    With the second set, do Pathfinder / Unite. You now have 4 object – the 3 main objects plus the 1 unified object.
    Apply the gradient to the united object and arrange it beneath the main outlined objects.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
