Activity Forums DaVinci Resolve Grade not applying to edit page.
  • Grade not applying to edit page.
    Posted by Sean Lennon on May 15, 2021 at 10:12 am
    Hi, i’m having a grading issue in resolve. I have a node branch, with some grading operations on each one, but they are not being applied to the edit page. They are being applied to the viewer, only when I have the highlight function selected but not if that is turned off. Its probably an easy solution but I can’t seem to find it. Any ideas as to what is going on here?
    Chuck Savadelis replied 5 years, 3 months ago 4 Members · 5 Replies
  • Jon Zanone
    May 15, 2021 at 1:25 pm
    At the top right of the record monitor there’s an icon that looks like a circle with stars in it. It should look like the picture below. If it has a red slash through it, it means the color grade is inactive (usually to speed up performance). Click it again and you should see your grade again.
  • Joe Marler
    May 15, 2021 at 5:40 pm
    I’ve seen that happen several times on Resolve 17.x and I think also in 16.x. What if you delete all render files and re-launch Resolve? Does it happen then?
  • Sean Lennon
    May 17, 2021 at 8:21 am
    Thanks for the suggestion but no red slash.
  • Sean Lennon
    May 17, 2021 at 10:40 am
    Thanks, tried your suggestion, still no go though.
  • Chuck Savadelis
    May 18, 2021 at 4:09 pm
    Sorry if this is too simple, but is your node branch connected to the output node?
