Activity Forums DaVinci Resolve Grade effects whole timeline
  • Grade effects whole timeline
    Posted by Dan Davis on August 1, 2011 at 3:24 pm
    Sorry I know it must be very simple!
    Am grading a clip/node in the timeline and the whole timeline is being effected with
    the same grade. Any help would be great and then I’ll be flying!
    Dan.
    Marcus Frewin-ridley replied 8 years, 7 months ago 6 Members · 9 Replies
  • 9 Replies
  • Sascha Haber
    August 1, 2011 at 3:29 pm
    This is actually how Resolve works.
    Instead of bothering your clients with a million little things, it applies a fantastic overall grade
    It could also be the case you are in track mode instead of clip mode.
    Just guessing 😉
    A slice of color…
    DaVinci 8.0.1 OSX 10.7
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB eSata 6TB
    GTX 470 / GT 120
    Extreme 3D+ WAVE
    http://www.saschahaber.com
  • Margus Voll
    August 1, 2011 at 3:36 pm
    But yes look on the 2 a clock up on ui there are tabs and you have probably track mode enabled
    Margus
    https://iconstudios.eu
  • Dan Davis
    August 1, 2011 at 3:39 pm
    Thanks chaps!
  • Dan Moran
    August 1, 2011 at 3:47 pm
    Hey Dan,
    Is their a Red box at the top of the clip in the thumbnails ?
    If so you just need to right click on the clip and click batch copy.
    this will break the link for you between clips.
    I hope this helps!
    D
    Dan Moran
    DaVinci Application Specialist
    Blackmagic Design EMEA
  • Dan Davis
    August 1, 2011 at 3:55 pm
    There is, thanks mate.
    Dan.
  • Sascha Haber
    August 1, 2011 at 4:54 pm
    ahhhh….so everything is from one file I assume ?
    that explains it..
    Did you try and do a preconform that splits the one file into segments ?
    A slice of color…
    RAID0 8TB eSata 6TB
    GTX 470 / GT 120
    Extreme 3D+ WAVE
  • Christopher Adams
    August 1, 2011 at 7:10 pm
    Yeah if you forget to split the media that would do it.. Another thing to check is to right click on a clip and do batch unlink. Maybe they are all linked together?
    CJ
  • Dan Davis
    August 1, 2011 at 7:47 pm
    Hi again,
    Very new to Resolve…..coming from Color.
    The whole sequence was mixed/bakeddown, so all clips have the same name.
    So I assume I need to look out for this and a whole lot more!
    Looking forward to it.
    Thanks a lot.
  • Marcus Frewin-ridley
    January 26, 2018 at 8:33 pm
    I don’t see a red box (I have resolve 14) or anywhere saying batch unlink. Elsewhere I’ve been told to use local grades but when I select this, I lose the grade I had which I still want on most of the clips. How can I keep the grade I had on some clips and change the grade on others?
