Activity Forums Apple Final Cut Pro Legacy Grad Filter effect
  • Grad Filter effect
    Posted by Peter Wolsey on March 12, 2007 at 3:28 pm
    I need to darken the sky on a clip. Is there a simple way of adding a Grad Filter effect to a clip without exporting to Motion? I’ve searched the archives but no luck. Maybe there’s a plug in someone knows about?
    Blub06 replied 19 years, 6 months ago 4 Members · 4 Replies
  • Bouncing Account needs new email address
    March 12, 2007 at 3:35 pm
    One quick way is to create a “Gradient” in the Render generator, add it to the video track above your clip, and “mix” over your clip by a small amount.
  • Tom Matthies
    March 12, 2007 at 4:44 pm
    Or use Joe’s Filters. The set has a nice Graduated filter that will do just what you want. Lots of other useful stuff as well.
    Tom
  • Peter Wolsey
    March 12, 2007 at 4:53 pm
    As ever, this forum comes up with the answers! thanks Matt and Tom
  • Blub06
    March 12, 2007 at 5:02 pm
    You could also use the 4 or 8 point garbage matte that comes with FCP.
    Put a copy of the shot on the top layer, lower the opacity to the lower layer copy and put the filter on the top clip and adjust as needed. You can even key frame the thing for effects over time etc.
    Chris
