Activity › Forums › AJA Video Systems › Grabbing 24p directly from Varicam
  • Gary Adcock
    November 8, 2005 at 5:48 pm
    [pixeleyed] “Yet, I have tried this setting to capture shot 24p material, and the originally described symptoms were the result. “
    I do not understand “jerked up” do you mean you see the 24p judder? (or flicker)
    Your post does not explain what the problem you are seeing is
    [pixeleyed] “Is it correct to assume that you captured direct from the HDSDI stream off the camera?”
    As far as i know that is the only way to get video out of the camera, short of pulling a tape out.
    I do this at every single Varicamp I do post for. don’t capture bars and tone they are never laid to tape on a varicam at anything other than 60p.
    Let me ask a dumb question- is the camera set for PAL or NTSC? if you are using a camera set in a PAL country (60hrz) you will need to use the 24frame capture setting, if you are in a NTSC country the setting needs to be at( 59.94 hrz) for 23.98 capture
    Gary Adcock
    Studio37
    HD and Film Consultation
    Chicago, IL USA
Page 2 of 2
