Gpu Setting
Posted by Thayalan Paramasawam on October 24, 2012 at 8:58 amHi Good Evening Sir,
Is gpu works in rendering for mpeg2 for dvd.can gpu make fast rendering for mpeg2.how should i check the setting.pls adivice me on this matter.
Thank You
Thayalan ParamasawamThayalan Paramasawam replied 13 years, 10 months ago 5 Members · 12 Replies -
Steve Rhoden
October 24, 2012 at 4:03 pmAs long as you have the GPU enabled in Preferences, along with
a good GPU Video Card, it benefits your entire Vegas workflow.Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
1-876-832-4956 -
October 24, 2012 at 4:49 pmhi sir,(Mr.Steve Rhoden)
I need to check the setting…any way thanks for the adivice.Thank You
Thayalan Paramasawam. -
October 25, 2012 at 3:22 amHi good morning sir,
For enable the gpu in prefrences….which option i must choose…..they is many option…..example…..editing,general,video and more………pls guide me sir……i am using sv 11.Thank you
Thayalan paramaswam
Joost Zeeveneegelbeek
October 25, 2012 at 10:19 amI can’t find the thread about this problem which existed a couple of hours ago, that was about Pro12 crashing when trying to preview or render. I have the same problem. Took your advise and removed Vegas versions from the system, then re-installed 12. I have a brand new graphics card Ati Radeon HD 7000 series with 1Gb and GPU is ON. What else can I be doing wrong?
John Rofrano
October 25, 2012 at 11:11 pm[Thayalan Paramasawam] “For enable the gpu in prefrences….which option i must choose…..they is many option…..example…..editing,general,video and more………pls guide me sir……i am using sv 11.”
To enable GPU for timeline playback/processing go to:
Options | Preferences | Video
and under:
GPU acceleration of video processing:
select your Graphics Card.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
David Shirey
October 26, 2012 at 8:12 pmI don’t believe rendering mpeg2 out of Vegas is actually GPU accelerated. Intel’s next chipset is supposed to have hardware mpeg2 encoding built in which is interesting, but that won’t be out until next Spring I imagine.
John Rofrano
October 27, 2012 at 1:31 pm -
October 28, 2012 at 5:30 amGood Afternoon Sir,
Sir after i check my setting in the preferences for gpu enable…i have 2 option only :off and advanced micro,inc.(juniper).
i am using radeon hd 6770 graphic card.Sir i post the preferences setting.
Thank you
