Activity › Forums › Adobe After Effects › GPU role in AE
GPU role in AE
Posted by Dmitry Danilov on August 27, 2009 at 10:42 pmHello! I was wondering what role does the GPU play in After Effects? I mean, does it actually renders stuff or is it handled by CPU? Thanks in advance!
Curious Turtle replied 17 years, 1 month ago 4 Members · 3 Replies -
Todd Kopriva
August 28, 2009 at 1:12 amThe GPU can be used to accelerate rendering for both previews and for final output. Most people (including me), restrict the use of OpenGL rendering to the OpenGL rendering to OpenGL—Interactive, which uses the GPU for rendering as you modify properties and drag things around; but it falls back to the CPU when you’re not changing properties.
If you enable the Hardware Accelerate Composition, Layer, And Footage Panels preference, the GPU can also be used to accelerate the drawing of images to the screen. (See “Improve performance”.)
Some effects (including the Cartoon effect) can take advantage of the GPU, too.
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment. -
Erik Lindahl
August 28, 2009 at 10:32 amOne issue at the moment with having activated OpenGL previews (even if only the “interactive” setting) is that you get zero feedback on your video-output during the time you change something. It will update AFTER you’ve done a change but yeah… This renders the feature perhaps not useless but limited in it’s use in a lot of environments sadly.
Perhaps CS5 will give us both? GPU acceleration AND video-output? One can always hope… 🙂
Erik Lindahl
Freecloud Communication
Curious Turtle
August 28, 2009 at 12:30 pmAlso, some filters make substantial use of the GPU, Boris Continuum Complete for example.
Always check graphic card and driver compatibility before using the OpenGL features in After Effects.
Cheers,
BenCurious Turtle Pro Video
Training | Editing | Support
