Activity Forums Blackmagic Design GPU processing mode
  • GPU processing mode
    Posted by Eric Sternberger on May 12, 2014 at 12:13 pm
    … when using davinci 10.5 with the new MacPro and Dual D700s, what its the correct settings for the GPU-Processing Mode? Auto or better Open CL?
    The 10.4 installer put Cuda on my System. Is this of any disadvantage, since I don´t have Nvdia-Cards installed?
    Ericbowen replied 12 years, 4 months ago 2 Members · 1 Reply
  • Ericbowen
    May 20, 2014 at 4:14 pm
    Auto would default to Open CL because those are AMD cards. However setting that to Open CL shouldn’t change anything if you wanted to. No the Cuda installer wont effect your performance or stability since no Cuda cards are installed in the system.
    Eric-ADK
    Tech Manager
    support@adkvideoediting.com
