Activity Forums DaVinci Resolve GPU error after V8 upgrade?
  • GPU error after V8 upgrade?
    Posted by Andrew Smith on August 17, 2011 at 1:39 am
    I just upgraded from 7.1 to V8 following directions in this forum about just installing and updating database but now when i launch the app i get the error message “chassis 1: GPU Config Error: No CUda boards available”.
    I went and updated cuda in system prefs (driver version 4.0.31 / GPU driver 1.6.36.10) but still same error – after hitting ok and tring to launch any of my sessions i get a crash 🙁
    any thoughts on this?
    MacPro 4,1 OSX 10.6.8 / FCS3 / CS5
    2.26 ghz 8-core / 24GB RAM
    Nvidia GT 120/285 combo
    Mary Kay miller replied 15 years ago 4 Members · 3 Replies
  • Dan Moran
    August 17, 2011 at 8:02 am
    Hey Andrew,
    Can you send us the crash logs ?
    If you double click the Capture Logs button in this folder :
    Library/Application Support/Blackmagic Design/DaVinci Resolve/
    This will save a file to your desktop and if you could send that to :
    davincihelp@blackmagic-design.com
    I’ll have a look for you!
    D
    Dan Moran
    DaVinci Application Specialist
    Blackmagic Design EMEA
  • John Sellars
    August 18, 2011 at 7:49 am
    I had the same problem. Try switching the position of the GUI and the Cuda card. Worked for me.
  • Mary Kay miller
    August 29, 2011 at 10:24 pm
    I had this problem, but it did not happen after the upgrade. It had been working fine then one day I just started to get that same message. I rebooted my Mac and all was fine again.
