Activity Forums Adobe After Effects GPS cordinates as text overlay-any Ideas?
  • GPS cordinates as text overlay-any Ideas?
    Posted by Thomas Anderson on February 26, 2008 at 12:59 am
    I’m calling on the collective wisdom of the forum to guide me to a solution for a client request. I have an excel speadsheet with columns for frame, Latitude & Longitude for the entire 6000+ frames of the shot. The client would like that data composited over the video like a head-up display. No problem I say….oooppps, I REALLY don’t want to do this by hand frame by frame. Is there a plug in I can buy, or easy script that will read the exel file or a comma delimited text file and automatically update the data on a per frame data? I’ve gotten out of the cave after 7 years, and back into shooting and field production, so my AE plugin knollege is a little rusty. Any and all words of advice are much appreciated.
    Thanks, Tom
    Darren Chappell replied 15 years, 7 months ago 4 Members · 6 Replies
  • Steve Roberts
    February 26, 2008 at 4:10 am
    Go to DigitalAnarchy.com. They may have something.
  • Paul
    February 26, 2008 at 9:44 am
    Huge stab in the dark.
    Can AE read XML files? Maybe an expression could be written and then that comma delimited file could be read in as .csv or converted to an xml file.
    Flash would probably be able to do this with a little coding.
    The timecode plugin comes to mind also.
    My 1.5 cents.
  • Darren Chappell
    January 23, 2011 at 10:32 am
    Hi – My reply is a ‘little’ away from the original post date – However, I have conducted what I believe to be exactly the same exercise.
    By taking the Lat / Long of the GPS data (primarily exported to CSV, but also available in the KML – I have applied some ‘math’ via MS Excel to maintain integrity of position, but create pixel movement representative of map scale. Long and Short – I have ‘Print Screened’ the area of travel from Google Earth – Populated with the GPS data so that I have a ‘direct’ overlay of the route.. then taken the CSV data ‘modded’ and applied it to a solid ~(with trapcode effect for the sake of it), positioned the initial anchor to the start point, and ‘TADA’ works a treat – A little calibration of the math, but got there.
    If you want or need further explanation / help – feel free to shout.
    Regards
  • Paul
    January 24, 2011 at 5:30 am
    I would love to see an example of what you did.
    Sounds neat. From the original post I was shooting from the hip and never did this but am intrigued and wanting to learn more.
  • Darren Chappell
    January 24, 2011 at 1:23 pm
    I am at work at present, but will endeavour to try and upload some guidance (if it helps, possible send you the xls etc, that does the work)
    I have it configured for approx 40mile radius of travel, and overlayed onto a screen dump from Google Earth just to prove my math.
    Bear with me, and I will happily enlighten you.
  • Darren Chappell
    January 24, 2011 at 8:22 pm
    mail me – darren-chappell@sky.com
    I have RARred the XLS, CSV, KML and AEP (Including Overlay Map)
    about 500k
    Let me know.
