Activity Forums Adobe Premiere Pro GoPro Hero 4 2704 x 1520 (2.7) format
  • GoPro Hero 4 2704 x 1520 (2.7) format
    Posted by Greg Flory on February 18, 2016 at 7:31 pm
    Used above format to create residential interior video. 2704 x 1520 resulted in much wider field of vision and detail than 1920 x 1080.
    Is it possible to add 2704 x 1520 to Premiere Pro CS6 timeline and “zoom out” to 1920 x 1080 for export rather than crop? Is this available in CC version of Premiere Pro?
    Greg Flory
    Tim Kolb replied 10 years, 6 months ago 3 Members · 2 Replies
  • Tero Ahlfors
    February 18, 2016 at 8:14 pm
    You can put the footage in a full HD sequence then right click it and choose scale to frame size. The aspect ratio is pretty much the same so it isn’t really wider.
  • Tim Kolb
    February 22, 2016 at 11:11 pm
    If you use the motion controls (scale), you can be a bit more flexible…zoom in/out, etc with key frames in an HD sequence. You’ve got some real estate to play with there.
    TimK,
    Director, Consultant
    Video Producer at I-CAR
