Activity Forums Avid Media Composer Google Video
  • Google Video
    Posted by Wayne M on April 28, 2006 at 6:41 pm
    Please look at this video I have uploaded to Google and tell me why I have such bad interlacing.
    https://video.google.com/videoplay?docid=-2089235929168569892&q=blue+bonnet&pl=true
    It was originally 16mm film projected on a wall and shot using my Sony HDV Z1 Cam in DVCAM mode.
    Then it was simply placed in my Avid Adenaline and exported as a quicktime reference into
    Sorenson Squeeze using Goggle’s suggested settings.
    The only thing I can think of is that maybe it is because the fps is obviously different.
    BUT, it looks great on the transfer. Just when it is compressed does it look that bad.
    Thanks for any help I can get on this…
    Wayne M replied 20 years, 4 months ago 2 Members · 2 Replies
  • Duane Fulk
    April 28, 2006 at 7:49 pm
    What are the settings for google. I tried to find out on their site, but had to sign up to get to it….sorry…. Anyway it looks like a very small file. I have seen this when compressing files to small size, low bit rate, etc. I suggest trying a QT instead of a QT Reference and a better compression program if you have it, like Procorder. I have cleaned up a lot of bad compression from Sorrenson by using Procorder with the same settings. Just some thoughts…
  • Wayne M
    May 1, 2006 at 3:45 pm
    The system requirements for the Goggle Video Uploader are:
    You must be operating on Windows 98 or higher, Mac 10.3 or higher, or any OS that has Java 1.4.1 or higher in order to install the Uploader.
    You’ll need a broadband connection to upload video.
    Acceptable File Formats:
    The fastest way to get your videos included in Google Video is to submit each file in our preferred format. We accept video in AVI, ASF, QuickTime, Windows Media and MPEG formats, however, we currently do not accept Flash files. Specific video codecs we accept include H.264, H.263, MPEG 1/2/4 and motion JPEG.
    If you have a video in another format, we will do our best to interpret it, but cannot make any guarantees.
    We appreciate your patience as we work to accept a wider variety of video formats. If you’re unsure whether your videos are in a format we’re able to accept, we hope you’ll attempt to upload them onto our system. If there are any technical issues with your videos, we’ll inform you through your account.
    Quality Guidelines:
    Please upload the original source file. The higher the quality of the video you can provide to Google Video, the better your video will look on our site!
    For content originating from camera phones, webcams, etc., please upload your file as is.
    For content originating from a DV camera or other high quality source, we recommend encoding at full-frame size and a high bit rate (you won’t go wrong with interlaced MPEG2 at >5Mbps and 720×480 or 720×576 resolution).
