Activity Forums Adobe After Effects good 2d cartoon animator to have in skillset
  • good 2d cartoon animator to have in skillset
    Posted by Jonas Espinoza on March 13, 2006 at 5:14 am
    ive boarded out an idea for a friends music, it involved some cartooning. could just go more cut out animation with AE, but maybe adding a new trick to the mix might be cool. any ideas for what software out there that does cool keyframable shape animations that could output video. does flash render video? would that make sense to learn since its a good one to know? learning curve? thanks
    Alon_a replied 20 years, 6 months ago 2 Members · 1 Reply
  • Alon_a
    March 13, 2006 at 5:55 am
    Toon Boom is apparently the standard, check out Moho as well, Plastic Animation Paper, Bauhaus Mirage… You can export an image sequence from Flash and composite it into video in AE or elsewhere. Flash is certainly a good one to know, the other ones IMHO are more specialized – if you don’t do 2D for a living your time may be better spent with a 3D app.
    – Alon
