Activity › Forums › Adobe Premiere Pro › going to dvd from hd
Posted by Frédéric on June 4, 2007 at 4:56 pmHi,
When i export a sequence as dvd from a hd project 1920 1080 (hduncompressed, not hdv) i always get an 16/9 letterboxed image regardless if i choose 4/3 or 16/9 aspect ratio in the mpeg2 settings.
what i need is an 16/9 anamorph output (stretched image).
Somebody else had that problem? or am i doing something wrong?Regards, Fr
Steven L. gotz replied 19 years, 3 months ago 2 Members · 4 Replies -
Steven L. gotz
June 4, 2007 at 7:24 pmYou are likely NOT choosing 16:9, or 1.2 Pixel Aspect Ratio. But since we can’t see your settings, you are going to have to provide one heck of a lot more information in order for us to help you.
Steven
Frédéric
June 4, 2007 at 8:54 pmHi Steven,
here is the info you kindly asked – to help me.
matrox axiohd, hp certified system.
matrox 1080p uncompressed 10 bit pal projectThis is the first time i go from a hd timeline to dvd, did it numerous times in sd without any problem
I tried different settings in Matrox media encoder
fe: paldv 16/9 highquality 7 mb cbr 1 pass field order upper
pixel aspect ratio 4/3 and 16/9 give both the same mpeg letterboxed file!
also other settings i tried fe: pal progressive 16/9 high quality 7mb cbr 1 pass gave the same letterboxed mpeg for the 2 aspect ratiosso choosing the aspect ratio doesn’t change anything. i always get the letterboxed image…
one weird thing more, after your reply i wanted to output one more test, a straight export to dvd and weird is that when i go to my encoding settings my source is 720 576 instead of 1920 1080..and i only see that little part of my image…this stays even after a few reboots of the whole system..and i only have this with a straight export to dvd, not when i choose matrox media encoder…
i don’t say the problem isn’t related to my system – but feedback from other users that did this before would be welcome
regards, Fr
Frédéric
June 4, 2007 at 9:27 pmSteven,
i found the problem, you’ll always see that when you do something for the first time – in my case exporting to dvd from hd project – they cange something else also – the player to quality check our dvd is new and was wrongly setup, played everything letterboxed.
So everything works just fine now,thanks anyway,
regards, Fr
