Activity › Forums › Compression Techniques › Going from DV with 4 tracks to MP4 with 2 x stereo AAC audio tracks
  • Going from DV with 4 tracks to MP4 with 2 x stereo AAC audio tracks
    Posted by Geert Van den berg on May 7, 2008 at 7:59 am
    I already posted this question in the FCP forum, but I thought I might get some different answers in this forum.
    This is the link to the other post, with some added explanations as to why I need this: https://forums.creativecow.net/readpost/8/986645
    Basically want I want to achieve:
    Going from a DV file with 4 uncompressed audio tracks (2 x stereo tracks) to MP4 with also 2 x stereo tracks in AAC format.
    I can make this manually with QT pro, but that is not an option because I have to do large quantities of conversions.
    I already tried many things in FCP and Compressor, but the only way to retain the channel format is to select passthrough but then the audio is still uncompressed and too big for easy file transfer.
    Geert van den Berg
    http://www.wpp.nl
    Geert Van den berg replied 18 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
