Activity › Forums › Adobe Premiere Pro › going from 4K to 1080
  • going from 4K to 1080
    Posted by Paco Bech on June 19, 2012 at 8:46 am
    Hello, I want to edit a 4k project in 1080. I select a 1080 sequence and then I am changing the motion scale of the clips from 100 to 43 to fit the viewer and then rendering. Am i doing the right process or I can do all this without the rendering and downscaling? is downscale is necessary, is changing the motion scale in CS6 the best way?
    best regards
    Paco Bech replied 14 years, 3 months ago 2 Members · 2 Replies
  • Tero Ahlfors
    June 19, 2012 at 11:38 am
    You don’t need to scale them in the motion panel. Just select all clips in the timeline and right click -> scale to frame size.
  • Paco Bech
    June 21, 2012 at 6:49 am
    Thanks, I still need to render, is this the correct way to edit 4K in 1080?
    best regards
