Activity Forums Avid Media Composer Going back to Avid from AE
  • Going back to Avid from AE
    Posted by Jose Skaf on August 26, 2009 at 8:17 am
    Hi:
    I have at question I cant seem to get my head around..:
    I did a project in MC, a 1080p/ 25 project. (Pal)
    -Worked on DNxHD 120.
    -Went out of Avid with a QT reference for color correction in After Effects.
    -Did color correction in After effects from that QT reference of the project.
    -Now I’m trying not to loose any quality when I go out of AE, back to Avid.
    I have two options: Export out of After Effects with the QuickTime DNxHD codec and import that into Avid or export with the QT “None” option and go back to Avid.
    I did some one second tests and I can’t see any difference between the two options, but what bugs me is that the DNxHD file’s size is about 30MB and the NONE (no compression) file size is about 200MB.
    Does that mean that the NONE option has all that much more quality??
    Is there the recommended output to go back to Avid as clean as possible?
    I would appreciate the help.
    Thanks in advance!
    Jose Skaf replied 17 years, 1 month ago 3 Members · 3 Replies
  • Grinner Hester
    August 26, 2009 at 1:57 pm
    A bigger file will never mean it magicly made it better quality than the source.
    I still use the uncompressed meridien codec. I don’t have time to roll the dice on bugs as avid releases new tests for us so I stick with old faithful.
  • Scott Cumbo
    August 26, 2009 at 10:08 pm
    If you do the round trip in DNX your you’ll be fine.
    Scott Cumbo
    Editor
    Broadway Video, NYC
  • Jose Skaf
    August 27, 2009 at 7:43 am
    Thanks a lot guys!
