Activity Forums Apple Final Cut Pro Glytch on frame after import to timeline
  • Glytch on frame after import to timeline
    Posted by Patric Royal on February 13, 2021 at 3:47 pm
    Hi I am busy editing some footage and noticed three sections where there is a glytch on two frames after importing to timeline on fcpx 10.4.6. When I check the original on another drive it’s fine. Image attached. its the green line at the top. I just blurred out detail. It is a different looking glytch on the other frame on same clip. Will re-import but would like to know what could be the cause.
    Working on mid 2011 imac/16g ram/
    Davis Brown replied 5 years, 6 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    February 13, 2021 at 4:01 pm
    Does it happen on the same frame every time?
  • Patric Royal
    February 13, 2021 at 4:08 pm
    Hi Jeremy,
    Thanks for reply. I may have found the prob. I backed up on two drives and see that the one copy has the glytch, the other not. let me see how it pans out as it may have been that original download to that drive causing the problem which is still odd. Can I have some time to check it out and will let you know.
    Patric
  • Davis Brown
    February 22, 2021 at 3:38 pm
    Have you solved this problem?
