Activity Forums ARRI Glue Tools: ARRIRAW Toolkit for MacOSX – v2.0 now GPU accelerated!
  • Glue Tools: ARRIRAW Toolkit for MacOSX – v2.0 now GPU accelerated!
    Posted by Robert Monaghan on March 16, 2013 at 3:32 pm
    Hi Everyone,
    I am about to place ARRIRAW Toolkit v2.0 online, shortly. This new version is GPU accelerated!
    For those that haven’t looked at it, the ARRIRAW Toolkit is a QuickTime component that plays back your ARRIRAW sequences. When installed, most QuickTime compatible packages can load, play and transcode ARRIRAW footage, as if it were a movie. But without rendering, wrapping, or any other processes.
    For example, you could use an “Link to AMA Files..” menu command to import the ARRIRAW right into Avid MC 6. (With Avid MC 6.0.3, you can even play the files!)
    Or, with Compressor 4.0, you can export ARRIRAW into LogC or Rec709 ProRes movies at full Res, rather than just 1920×1080.
    Final Cut Pro 7 will also import and play the footage as well!
    The ARRIRAW QuickTime component uses ARRI’s own color science, so that color reproduction is spot on.
    (Keeping in mind that QuickTime itself adds Gamma and ICC profile corrections over top of the displayed imagery, of course. – Contact us for a better explanation, if needed.)
    The software “should” be compatible with ARRI Alexa SUP3 and later.
    Shortly, I will detail a list of compatible recorder hardware. So far, Codex equipment works well.
    I expect to have a downloadable posted soon.
    Notes:
    The new price for the basic package is $279.00 USD.
    This package no longer includes the ARRI LogC Filter. This will be updated an sold separately.
    The minimum system requirements is MacOSX 10.7.5, with an OpenCL compatible GPU.
    MacOSX 10.8.3 is highly recommended. A high speed RAID is also needed for playback.
    Bob..
    Robert Monaghan, CEO
    Glue Tools LLC
    POBox 24124
    Santa Barbara, CA, 93121
    United States
    tel: +1 805 456 7997
    fax: +1 805 456 7998
    http://www.gluetools.com
    Robert Monaghan replied 13 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
