Activity › Forums › Maxon Cinema 4D › gltf export plugin won't install on R20
  • gltf export plugin won't install on R20
    Posted by Hilary Tsai on October 16, 2022 at 9:38 pm
    Update: It did end up working, I did a dumb thing and confused versions because I have more than one C4D installed…
    Sorry for the trouble, you can delete this on your end, mods. I don’t think I have the option to do it on my end.
    I extracted the glTF exporter plugin to a new plugins folder which I created, and changed the preferences within R20 to point to that folder. After restarting, the plugin does not appear; there is still no option to export glTF.
    At first, I was encountering an error that the plugin had to be trashed because they couldn’t tell if there was malware on it. I overrode that through my security preferences, so there should’ve been no problem installing the plugin. On subsequent tries, the error didn’t come up, so I assumed the install had gone well. I do not have any clue as to what’s interfering with it. I’m running Mac OS Monterrey and R20, I got the plugin from here: https://www.cineversity.com/vidplaylist/maxon_labs_plugins/gltf_exporter
    Hilary Tsai replied 3 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
