Activity Forums Zaxwerks glow question
  • glow question
    Posted by Dave Hirschberg on May 12, 2005 at 3:28 pm
    I created a neon light and want it to glow but I don’t want the object it is over to glow. Is there a way to add a glow to one object and not another in the same comp window?
    Matt Rhodes replied 21 years, 4 months ago 2 Members · 3 Replies
  • Matt Rhodes
    May 12, 2005 at 3:45 pm
    Hi Dave.
    Easy Glow (part of The Werks Vol. 1) provides a Glow Style called “Out-Glow”, which will
    put a glow on the outside of the object, leaving the inside intact.
    This is probably what you would use for a good neon glow.
    You can even change the Glow Color From parameter to “This Layer”, which will make your
    layer’s color the glow color.
    Give this a try and let us know if you have any other questions.
    Matt Rhodes
    Zaxwerks, Inc.
  • Dave Hirschberg
    May 12, 2005 at 3:50 pm
    Will this work in AE 5.5?
  • Matt Rhodes
    May 12, 2005 at 7:47 pm
    Hi Dave.
    Absolutely.
    Matt Rhodes
    Zaxwerks, Inc.
