Activity Forums Adobe After Effects Glow Little Glow Worm….
  • Glow Little Glow Worm….
    Posted by Glenn Takakjian on June 17, 2005 at 5:27 pm
    I’ve got a 3D object I created in C4D. It is rotating and as it does pieces of it are fading in… so it is a build. I do these type of fades in AE so you get “solid” fades instead of seeing the underlying geometry when fading in C4D .
    So I have overlapping tiff sequences with a 1 sec fade on each overlap.
    I want to add a glow. If I add the glow to each individual layer the glows are additive and then Blink out when the lower fading sequence ends.
    If I make a comp of all elements fading and then add the glow effect to the comp it blinks in about 3/4s of the way through the glow. The glow effect seems not to enable until the opacity level reaches a certain point.
    Is there a way to get a smooth glow as all these pieces fade in?
    Aharon Rabinowitz replied 21 years, 2 months ago 2 Members · 1 Reply
  • Aharon Rabinowitz
    June 17, 2005 at 8:20 pm
    Instead of using the glow effect, which I find a biot moody, why not try this:
    Pre-comp the entire object fade-in sequence you have, and then when you drop that comp into your final comp, suplicate the layer, and on the top of the 2 layers, add a blur, and change the transfer mode to “add” – play with the transparency a bit.
    Maybe that will help.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
