Activity Forums Adobe After Effects Globally change background color of a project
  • Antony Buonomo
    April 19, 2010 at 2:58 pm
    This may be too much work after the fact, but you could put the same new solid as the bottom layer in every comp, if you then do Command-Shift-Y you can change the colour and then check the box that says something like “do you want to apply this change to every instance of this solid?”
    A
    Vertigo Productions
    https://www.vertigo.co.uk
  • Jason Brown
    April 19, 2010 at 6:11 pm
    [Dave LaRonde] “If not having a consistent background color for your comps just drives you nuts to the point of incapacitating your work”
    Not really, just curious if it was a possiblity. Thanks guys…
