Activity Forums Apple Final Cut Pro Global Change ?
  • Global Change ?
    Posted by Joe Zabrosky on October 20, 2014 at 7:43 pm
    After 32 band equalizing one clip in the graphic equalizer in the audio enhancement section of fcpx is there a way to globally equalize hundreds of audio clips with the exact same equalization i made to the first clip just mentioned. Or, do i have to go into each of the 100s of clips and make the changes manually?
    I have used the match tool to match the overall sound of a clip to various other clips but it appears that the match tool does not allow me to match the exact 32 band equalization i do to 1 clip. Am I correct in saying this or wrong? Boy, do I hope I’m wrong.
    Thanks, joe
    joseph zabrosky
    Joe Zabrosky replied 11 years, 10 months ago 2 Members · 2 Replies
  • Mark Smith
    October 20, 2014 at 8:53 pm
    Copy original clip then, select other clips in the time line index, then paste attributes, tick off the audio check box . Done?
  • Joe Zabrosky
    October 21, 2014 at 7:31 pm
    Thanks Mark – I should have known that. Thanks again!
    joseph zabrosky
