Activity Forums Apple Final Cut Pro Legacy Global attribute changes in FCP
  • Global attribute changes in FCP
    Posted by Brooks Reid on June 27, 2007 at 5:38 pm
    I have a 2 hour film shot in Anamorphic DV on a timeline in FCP. Each clip in the time line has it “distort” attribute set to “-33” for viewing on a SD 4:3 monitor. Now I want to output the entire film to it’s full 16:9 widescreen so I need to change every clip in the timeline’s attrbute to “distort 0”.
    Is there a way to globally change attributes in FCP?
    I’ve tried nesting to a new timeline but the clips retain there distortion.
    I’ve tried changing the timeline’s settings but have the same problem.
    Help!
    Brooks Reid
    Miami, FL
    John Pale replied 19 years, 3 months ago 2 Members · 1 Reply
  • John Pale
    June 27, 2007 at 6:01 pm
    Just select every clip in the timeline…right click and select “remove attributes” then check distort.
