Activity › Forums › Adobe Premiere Pro › Glitchy Video artifacts when using AME output to H.264 .F4V
  • Glitchy Video artifacts when using AME output to H.264 .F4V
    Posted by Jim Bachalo on June 22, 2011 at 8:50 pm
    Hi
    having a problem with ‘glitchy’ video artifacts when my flash video first plays.
    Otherwise the quality is fantastic.
    I figure if I play with some of the h.264 compression settings in Adobe Media Encoder I can alleviate the problem but don’t know where to start….
    Local is the new global
    Vince Becquiot replied 15 years, 3 months ago 2 Members · 1 Reply
  • Vince Becquiot
    June 22, 2011 at 9:10 pm
    Hi Jim,
    Usually, this is combination of keyframe interval; being too low, and/or bit rate being too low.
    Try shortening the keyframe interval first. This is a point in the video where the compression provides a full frame, not just changes from the previous frames. If the interval is too long, you will start seeing artifacts on fade ins, and crossfades, where every consecutive frame is different.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
