Activity › Forums › Adobe After Effects › glitchy text
glitchy text
Posted by Anass Moujrid on August 3, 2022 at 7:25 pmany help with this would be much appreciated. I’ve tried fractal noise and displacement map with no proper results.
Anass Moujrid replied 4 years, 1 month ago 2 Members · 5 Replies -
Thiago Macedo
August 3, 2022 at 8:20 pmI’ve set up a simple project for you. I think you can work your way from this file.
Let me know if you need more explained details about. -
Anass Moujrid
August 3, 2022 at 9:41 pmHi Thiago!
Thank you so much for your output. In fact, the media file that i uploaded was in GIF format. it is an animated glitchy slicy text that runs in a different way.
please check this pinterest link to have a clear idea https://www.pinterest.com/pin/769060073880372223/
Thank you fr your interactivity! Obrigado
Anass Moujrid
August 3, 2022 at 9:46 pm -
Thiago Macedo
August 3, 2022 at 11:04 pmLook, this “restless” example was done manually, you can notice this because every line has the same behaviour and the amount of synchrony between actions. I thought you showed it as an example and not an exact copy. I’ve attached a project which reproduces the effect in exactly with just 3 steps.
Anass Moujrid
August 4, 2022 at 10:30 amI’m grateful for your help Thiago! I’ve checked your behance portfolio and it looks amazing!
I’m a journalist and I seek deepening my motio graphics skills. If you don’t mind here is my pinterest profile. I’m very active on this platform and you’ll certainly find many inspiring things : https://www.pinterest.com/amoujrid/
you can send me a message there!
Thank you so much for dedicating time to respond to my question!
