Activity Forums Adobe After Effects Expressions Glitches with animation using .toWorld expression
  • Glitches with animation using .toWorld expression
    Posted by Sean Platt on February 25, 2016 at 12:40 am
    Hi There. I am new to the expressions world and am trying to use the .toWorld expression to parent a shape layer to a null layer that will change in position but not change in scale. The problem I am running into is I will have an occasional frame that puts the null layer somewhere else on the stage even though there is no keyframe in the position property for the shape layer or null layer and the null does not appear to move- just the shape. I have attached a screenshot of two frames that are side by side in the timeline to illustrate. Does anyone have any clue why this is happening? The expression works on many many other shape layers in the same file. It is just a few of them that go astray for a frame here and there. Any help is appreciated. Thanks. I am using CS6.
    thisComp.layer("241N").toWorld([0,0]);
    Dan Ebberts
    replied 10 years, 7 months ago
    2 Members · 1 Reply
  • Dan Ebberts
    February 25, 2016 at 1:43 am
    I’m not able to view your images for some reason.
    Dan
