Activity › Forums › Apple Final Cut Pro › glitches during playback in timeline as well in rendered movie
Posted by Pieter Vlamings on February 6, 2020 at 1:37 pmDuring play back I get these glitches. I tried several things but it won’t disappear.
Jeremy Garchow replied 6 years, 6 months ago 3 Members · 4 Replies -
Jeremy Garchow
February 6, 2020 at 3:59 pm[Pieter Vlamings] ” I tried several things but it won’t disappear.”
Have you deleted your cache?
Are the glitches present in source footage when you play through Quicktime or any other system other than FCPX?
Pieter Vlamings
February 10, 2020 at 7:50 amHello Jeremy,
I threw the cache away, but that doesn’t help. It Also has glitches while playing in VLC.
When I worked on the project ast year it didn’t had this problem. -
Joe Marler
February 10, 2020 at 1:21 pm[Pieter Vlamings] “Also has glitches while playing in VLC.”
Are the glitches in the *source* footage that was imported to FCPX? If so it’s likely not an FCPX problem. Can you describe or post an image of the glitches?
What camera, frame rate, resolution, bit rate and codec? You can inspect those things using Quicktime Player 10’s menu: Window>Show Movie Inspector.
Jeremy Garchow
February 10, 2020 at 1:23 pmIf it’s glitching in other applications that suggests a few things.
Does it glitch in the same frames repeatedly, or is it random?
Do you have more than one machine to play back on?
Either your computer might be failing (perhaps a GPU) or your media somehow is corrupted.
Of you have another machine, try playing the media back on it and see if you see the glitches. Try and note the frames to see if the glitches repeat on the same frame.
