Activity Forums Adobe After Effects Glitch on render
  • Glitch on render
    Posted by Randy Mcwilson on May 10, 2012 at 7:02 am
    I am regularly getting a one-frame glitch, almost always located in the lower half of a frame that shifts everything over to the right 20-50 pixels and is sometimes dark or slightly brighter than the rest of the image. It rarely happens more than once in a rendered clip, and almost always in the fist 5 seconds. Render always 1080p, Photo-Jpeg .mov
    Here is a sample image:
    Specs: i7-PC 12MB Ram, AE CS5.5, GTS-450 GPU
    Rendering to internal SATA drive.
    Any ideas?
    Eternity…don’t miss it for the world.
    Randy Mcwilson replied 14 years, 1 month ago 2 Members · 2 Replies
  • Roland R. kahlenberg
    May 10, 2012 at 1:25 pm
    1) Ensure that you have the latest QuickTime which is proven to be compatible and stable with your OS.
    2) Does the issue appear with a specific plugin/effect?
    3) Try a different CODEC.
    4) Try purging the memory prior to a render – Edit>Purge>All Memory.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Randy Mcwilson
    August 8, 2012 at 7:42 pm
    SOLUTION FOUND!!!
    It was my computer memory. I had one stick of RAM that was different from the original memory with the machine. Apparently the inconsistencies of latency or otherwise glitched outputs.
    Pulled the offending stick of ram and now outputs are PERFECT.
    thanks
