Activity › Forums › Adobe After Effects Expressions › Glean the size of the bounding box created by a continuously rasterized precomp?
  • Trent Armstrong
    December 2, 2021 at 1:32 pm
    Just spitballing here …
    Not sure how efficient it is, but maybe you could put four nulls in your precomp to that are programmed to use position themselves at the four furthest points of your elements in the precomp and average out the Z position. Then, when you continuously rasterize, you’ll have the bounds already located and would be able to use toComp() to locate the null positions and extrapolate your desired result.
    This is a cool problem to solve! Following!
    Trent
