Activity › Forums › Apple Motion › Glacial Motion 4 – for just THIS project?! tried most everything
  • Glacial Motion 4 – for just THIS project?! tried most everything
    Posted by Stu Aull on April 2, 2012 at 9:34 pm
    Cheers folks:
    getting 1fps preview/playback in Motion 4 on just this one project.
    Played back MUCH better earlier (like: 20fps+, last week) when original constructed.
    Mac Pro latest,
    12Core – 16GB RAM
    OS 6.8
    √Usual 1st step of delete the pList in Prefs –
    √numerous re-boots of computer betw these ops
    √copied/renamed file
    √turned OFF all the fancy “Shadow/depth of field/motion blur” playback functions
    √even set to DRAFT (which I did NOT have to do originally)
    √even set to 1/4 resolution playback (which I did NOT have to do originally)
    √cleared RAM preview
    Opened other projects and they perform fine.
    stumped!
    thanks in advance
    Stu Aull
    Alaska
    Stu Aull replied 14 years, 6 months ago 2 Members · 3 Replies
  • Stephen Smith
    April 2, 2012 at 9:37 pm
    How long is this video? Does it use the replicator or particles a lot? Does it have a lot of layers?
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
  • Stu Aull
    April 2, 2012 at 9:43 pm
    OK-
    should add
    -30fps/30sec/900frame
    1080iHD project
    I loaded the “naked” version of this file (it is a purchased template), and without all the DropBox images (ie mine, all under 1MB), it plays at 9fps. Still glacial.
    I do a LOT of SD in motion, so maybe I expect too much from HD? But, Jeez!: 12Core/16GB Ram? I mean…
    really??
    Stu Aull
    Alaska
  • Stu Aull
    April 2, 2012 at 9:49 pm
    Hi Stephen! (love your tutorial stuff)
    Its fairly complex (but jeez, its motion so aren’t most??)
    5- camera layers (1 after the other)
    11 drop zones (floating pictures)
    3 background “walls” -images
    1-power-sucking light flare, which I disabled and actually layered in a second pass, so presume “turning it off” should speed things up (certainly did for the render!!)
    Again – this whole project was speedy enough last week to allow me to run to at least judge ease-in/outs etc in playback but NOW at 1fps?? no way 🙁
    cheers
    Stu
