Activity › Forums › Canon Cameras › GL2 Doesn’t Remember Settings
  • GL2 Doesn’t Remember Settings
    Posted by Derekkent on May 17, 2006 at 1:17 am
    Hello,
    I find that the aperature/fps/and so on settings are not being remembered by the camera.
    for example, i turn the cam on (on manual mode) it shows
    60i
    1.2
    18Bb
    I set it to
    30f
    1.8
    0db
    i shoot something, or whatever, i turn the cam off, i turn it back on, and the settings are again
    60i
    1.2
    18
    does the GL2 simply not have memory for its settings? or do i have something set improperly?
    thanks for any help
    adding me to msn is fine
    “have you seen that new movie?”
    “which one? is it black and white and shot on film?”
    “no”
    “oh, well, that’s not ‘art’ then…”
    “….oh”
    Derekkent replied 20 years, 3 months ago 3 Members · 3 Replies
  • Don Greening
    May 17, 2006 at 4:54 am
    [DerekKent] “does the GL2 simply not have memory for its settings? or do i have something set improperly?”
    Hi Derek,
    Mine does the same thing, so it must be an inherent weakness of the breed. If you’re thinking it might be time for a new memory battery, if your custom preset settings are retained but your shooting mode/aperture settings are not then I would suspect that there’s really not much you can do about it. Previous white balance setting is not retained either, which is a bit of a pet peeve of mine with this camera. However, I have found that if you take the lens cap off before you fire up the GL2 the aperture settings will be much closer to the proper exposure. So at least that’s something.
    – Don
  • Grady Knight
    June 13, 2006 at 8:50 am
    Right side of cam, around the pause/rec RED button there is a “LOCK/STANDBY” switch. Use this rather than the camers/off/play(VCR) switch and it will retain ALL settings.
    Hope this helps you…
    8mm & 16mm film to DVD
  • Derekkent
    June 15, 2006 at 9:38 am
    well,
    thanks for the suggestion, but that doesn’t turn the camera off..
    my concern was really with keeping settings for longer than just during a shoot..
