Activity › Forums › Adobe After Effects › Give Mask Vertexes Curved Pathing?
  • Give Mask Vertexes Curved Pathing?
    Posted by Phillr on August 13, 2006 at 12:34 am
    I have a stopwatch animation, and as the second handle spins, I want it to leave behind a red area so that after one rotation, the face of the stopwatch is red.
    I tried doing this using a changing mask shape over time. But my mask’s vertex points move along a linear path (quickest possible path from point A to point B) whereaz I want them moving in a circular motion. Is this even possible?
    Is there any other way I could create this animation?
    Phillr replied 20 years, 1 month ago 2 Members · 2 Replies
  • Mike Clasby
    August 13, 2006 at 1:13 am
    Methinks you want Transition>Radial Wipe to reveal a Red Solid layer below (or whatever Red type layer you have in mind). Just set the center and Animate the Transition Completed (%) to match the second hand. You may need masks to make the Revealing red face fit the stopwatch.
  • Phillr
    August 13, 2006 at 2:02 am
    … o-m-g
    can’t believe i forgot a simple solution such as that. thanks mike!!
