Activity Forums Apple Final Cut Pro Legacy ghosting image and weird lines – canon handycam
  • ghosting image and weird lines – canon handycam
    Posted by Wesley Volschenk on February 2, 2011 at 12:10 pm
    Hi There
    I have been given some footage captured on a Canon Legria HFR106. This is little HD handy cam that captures .mts files using AVCHD codec. I am told they shot in full 1080 at 25fps.
    Now when I take this through FCP log and transfer I end up with 1920 x 1080, 25fps, apple pro res 422 (HQ), with a data rate 22.1mb/sec, no fields.
    The footage has these weird lines and ghosting, even if i export it! I called Canon and they say I should speak to Apple. UH?
    What can I do to save this footage?
    Wesley Volschenk replied 15 years, 7 months ago 2 Members · 2 Replies
  • Jeff Greenberg
    February 3, 2011 at 1:57 am
    Try viewing the .mts files in MPEG streamclip or VLC player – see if those lines are there all the time. Also make sure you’re viewing the canvas at 100% to check the full quality.
    Best,
    Jeff G
    Apple Master Trainer
    Avid Cert. Instructor DS/MC
    Avid & Color Videos Vasst.com
    Compressor Essentials Lynda.com
  • Wesley Volschenk
    February 3, 2011 at 7:00 am
    Hi Jeff
    These .mts files do not want to play in mpeg streamclip or VLC.
    I have also looked at the footage at 100% and have tried to export it to see if that helps, but no joy, once again.
    Wesley
