Activity › Forums › Adobe After Effects › Ghost effect – edges of actor to emanate away / dissolve
  • Ghost effect – edges of actor to emanate away / dissolve
    Posted by Declan Smith on May 4, 2014 at 9:02 am
    Could anyone help with this effect I am trying to achieve.
    I have a green screen clip of an actor and I am trying to get the effect of the edges of the character emanating outwards / dissolving, almost like streaks of smoke, and using the colouring of the edge where it came from. Also, as the character moves, this effect must stay with the edge. I want this to be subtle as it’s hinting that the character is a ghost. I have tried a few things, but just can’t quite get the right combination and now could do with fresh ideas. For example, I’ve tried getting particular to create particles, but can’t get them to look right or emanate from the edges properly. I’ve tried edge finder and turbulent displacement. I’ve even tried a variation of VideoCopilots solar flare.
    Some inspiration from the community would be greatly appreciated.
    Declan Smith
    https://www.madpanic.tv
    After Effects CS6/ FCS3 / Canon XLH1 / Canon 7D / Reason / Cubase
    “it’s either binary or it’s not”
    Declan Smith replied 12 years, 5 months ago 3 Members · 4 Replies
  • Roland R. kahlenberg
    May 4, 2014 at 2:56 pm
    Howzabout this – duplicate the keyed layer and scale it up. Place it behind the original. Adjust the duplicate’s opacity and Blending Mode and apply a distortion effect. Oh, you may want to set the duplicate’s Anchor Point to the center of the character prior to scaling – some motion tracking may be required.
    HTH
    RoRK
    Gaudy Teaser Promo for an upcoming AE Type Gizmo.
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    Imagineer Systems (mocha) Certified Instructor
  • Shahed Naderi
    May 5, 2014 at 1:44 am
    how is the footage ? where is the actor ? is the head moving or not ? footage is shaky or steady ?
    no link to footage ?
  • Declan Smith
    May 5, 2014 at 8:03 am
    I can’t put the footage online, but it is straight forward green screen shot of actor. One wide shot, a couple of mids and a close up. There is not much movement other than other than the character talking, although the last CU shot he steps out of shot, nothing that can’t easily be tracked.
    Declan Smith
  • Declan Smith
    May 5, 2014 at 8:06 am
    Thanks, I have started experimenting with this method and looks promising. I need to get the right combustion of distort / blurs now
    Declan Smith
