Activity Forums Adobe Encore DVD getting transistions to look smooth…
  • getting transistions to look smooth…
    Posted by Andy Brennan on May 17, 2007 at 12:22 pm
    I’m experiementing for the first time with putting a transition from the main menu to a submenu. Everything seems okay, except when the transition is over, it doesn’t smoothly go into the submenu; there’s a black flash like it’s resetting. In a way that kindof defeats the purpose of having a transition, because there’s no smoothness.
    Will that always be there? I want the end of the transition to instantly and smoothly become the submenu to which its targeted.
    Andy Brennan replied 19 years, 3 months ago 2 Members · 2 Replies
  • David Garrett
    May 17, 2007 at 1:32 pm
    is the black frame showing on the Encore Preview??? it should not be so noticeable on the burned DVD..
  • Andy Brennan
    May 22, 2007 at 2:13 pm
    Hey, yes, thank you…
    The problem is fixed when you burn a DVD. Encore’s “Preview” doesn’t handle it, but when you burn, it’s okay.
