Activity › Forums › Apple Final Cut Pro Legacy › getting the 16:9 look for old newsreel foootage
Posted by Nick Natteau on March 26, 2010 at 5:47 pmSorry to be repetitive as some of you might have seen this post in other forums, but I like to post on different forums to maximize feedback.
For an upcoming HD doc-film I plan to make on WWII, I remain unsure as to how to display the 4:3 footage in my 16:9 720p timeline. Most people have advised me to jnot tinker with it and leave it pillarboxed.
But after seeing Michael Moore’s doc-film “Capitalism: A Love Story”, I couldn’t help noticing that none of the old (40s and 50s) newsreel footage he used in his film was displayed 4:3. And this included some 8mm or 16mm home movies which must have been 4:3. Some of these clips looked like they had been upscaled actually fill the 16:9 frame, because the framing was quite tight.
In any case, I reposted a WWII clip here upscaled in three different ways: https://vimeo.com/10464166
just to get some more feedback on what would work best visually.I’m worried that it might be too visually distracting to transition between my 720p 16:9 interviews to pillarboxed footage.
But I also have no idea what the acceptable standard is for distribution: are we allowed to scale up 4:3 footage in order to fill the 16:9 frame, or instead stretch it horizontally? Is there a general rule?
– Nick
Greg Hammons replied 15 years, 4 months ago 7 Members · 13 Replies -
David Roth weiss
March 26, 2010 at 6:06 pm[Nicholas Natteau] “I’m worried that it might be too visually distracting to transition between my 720p 16:9 interviews to pillarboxed footage.
“Whoever told you to leave it pillarboxed should be sent to Siberia. There aren’t any docos on TV that do that any more.
Not only that, but many broadcasters, including PBS, have rules about this kind of thing, and they no longer accept anything pillarboxed.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
EPK Colorist – UP IN THE AIR – nominated for six academy awards
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Nick Natteau
March 26, 2010 at 6:47 pmHi David,
Thanks very much for your feedback. So then what’s the rule for 4:3 footage in an HD program?
Scale it up until you fill the 16:9 frame or stretch it slightly horizontally?
Someone suggested filling the sides with blur, but I’ve only seen that on news networks like CNN and Fox.
To me that effect (blurring the sides) looks a bit cheesy and quite distracting.Thanks,
– Nick
John Fishback
March 26, 2010 at 7:05 pmGiven the already archival-looking clips, zooming them full seems to work fairly well. I’m not sure how you stretched the clips, but if you haven’t already, checkout Andy Mees’, “Andy’s Elastic Aspect” plugin.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Nick Natteau
March 26, 2010 at 7:18 pmHi John,
To stretch it horizontally, I simply changed the aspect ratio to -33.33 which took my 4:3 pillarboxed image and stretched it until it filled up the 16:9 frame.
John Fishback
March 26, 2010 at 7:34 pmTry stretching with Andy’s plugin. It allows you to define a “safe” center area which is stretched less (if at all) than the outside area.
John
David Roth weiss
March 26, 2010 at 7:58 pm[Nicholas Natteau] “So then what’s the rule for 4:3 footage in an HD program? “
Well, every case is a little different, depending on the nature of the SD video you’re dealing with, what you’re cutting it next to in the timeline, and what you’re trying to communicate.
[Nicholas Natteau] “Someone suggested filling the sides with blur, but I’ve only seen that on news networks like CNN and Fox.
To me that effect (blurring the sides) looks a bit cheesy and quite distracting. “I agree completely. I’m not a fan of any of the techniques mentioned above. In addition, other than Andy’s plugin, which preserves the center and stretches the other parts, I’m not at all a fan of stretching, and instead prefer scaling up until you achieve full frame, no matter what the number may be.
I’m a big fan of beat up stock footage, and you’ll often hear me saying that it turns on the “wayback machine” for the viewer, a term I’ve stolen from the old Hanna Barberra cartoon IMPROBABLE HISTORY, that you may remember with Mr. Peabody and his sidekick Sherman.
Of course, there are many ways to improve the blowup other than just scaling on the FCP timeline, such as running through Teranex hardware or through a capable I/O device such as a Kona card. However, many times this is just not necessary, as scaling on the timeline yields results that simply make the footage more realistically older looking.
David Roth Weiss
Nick Natteau
March 26, 2010 at 8:38 pmHi David,
I agree. I just purchased the Matrox MXO2 and I’m using that hardware it to upscale my clips from 480i to 720p. But I still wind up with a pillarboxed image unless I scale the image up further in FCP (actually 135%) to fill up the 16×9 screen.
The problem with scaling up to 135% is that I would have to readjust the framing. Not a big problem. I just thought that stretching the upscaled image horizontally would fill up the screen with less hassle (not having to reframe everything). I’ll go ahead and download Andy’s stretch filter.
Is it OK to upscale WWII footage inside FCP? So far everyone told me to use hardware if possible. But upscaling inside FCP would save me a huge amount of time. I would not have to offline and recapture everything.
David Foster
March 26, 2010 at 8:54 pmGreat thread here. I’m just adding a correction. Peabody and Sherman were not Hanna/Barbera. It was by Jay Ward ( Rocky And Bullwinkle J Moose).
Sorry for the interruption
David Foster
David Roth weiss
March 26, 2010 at 8:55 pm[David Foster] “Great thread here. I’m just adding a correction. Peabody and Sherman were not Hanna/Barbera. It was by Jay Ward ( Rocky And Bullwinkle J Moose). “
You are so right!!! My bad there.
David Roth Weiss
David Roth weiss
March 26, 2010 at 8:59 pm[Nicholas Natteau] “s it OK to upscale WWII footage inside FCP?”
I’ve done it. That footage is so many generations down by now that it makes little difference what you do to it, it always looks good and the more stepped on the more genuine. Just go for it and let FCP help to turn on the wayback machine for your audience.
David Roth Weiss
