Activity › Forums › Apple Final Cut Pro Legacy › getting the 16:9 look for old newsreel foootage
Greg Hammons replied 15 years, 4 months ago 7 Members · 13 Replies
Arnie Schlissel
March 26, 2010 at 10:01 pm[Nicholas Natteau] “Is it OK to upscale WWII footage inside FCP?”
Hold on, let me check my copy of the Geneva Convention. 😉
I might try scaling in AE or Motion. You should run some tests. Your options are to either scale all the footage before hand, or just wait until you lock picture & then scale only what you’re using.
Arnie
Post production is not an afterthought!
https://www.arniepix.com/ -
Jason Porthouse
March 29, 2010 at 6:13 pmI find it odd that anyone thinks it’s acceptable to have stuff at the wrong aspect ratio, which it would be if stretching 4:3 to the 16:9 frame of HD.
A recent feature length doc I cut had around 20 minutes of archive, all from SD. I did a quick n dirty resize in FCP for the ‘offline’, then redid the blow up for the online using ReSizer, though I think that’s no longer available. Motion does a pretty good job at upscaling these clips too.
Please, no stretching. The world has enough short, fat people and only clowns cars have oval wheels.
Jason
_________________________________
Before you criticise a man, walk a mile in his shoes.
Then when you do criticise him, you’ll be a mile away. And have his shoes.*the artist formally known as Jaymags*
Greg Hammons
April 16, 2011 at 10:13 pmHello David,
I am doing a similar project (Documentary in FCP DVCPRO HD 720/30p to be broadcast on local PBS station). I have a Kona LHe card and was wondering about your comment:
Of course, there are many ways to improve the blowup other than just scaling on the FCP timeline, such as running through Teranex hardware or through a capable I/O device such as a Kona card.
I am using DVDxDV PRO to rip the archival footage from DVD’s. There is a extract preset that allows the use of the Kona card presets. Should I use this program to run through the Kona card or some other method? If so, what do you recommend?
