Activity › Forums › Adobe After Effects › Getting seperate layers to do same movement
  • Getting seperate layers to do same movement
    Posted by Jamie Young on June 3, 2011 at 4:23 pm
    I have a movie clip in a layer and a solid layer behind it and I want both to movie to the same wiggle effect. How do I do this?
    Jamie Young replied 15 years, 4 months ago 3 Members · 3 Replies
  • John Cuevas
    June 3, 2011 at 4:53 pm
    Add a wiggle to one of the layers and then parent the 2nd layer to the first.
    Johnny Cuevas, Editor
  • Kevin Camp
    June 3, 2011 at 5:30 pm
    if for some reason parenting won’t work, you can set the expression to use the random seed value, and thus produce the same random values for wiggle().
    add this above the wiggle() expression:
    seedRandom(1);
    you can set the value in the () to any integer (ie. 5, 99, etc), just make sure they are the same for both expressions to get the same random values.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Jamie Young
    June 4, 2011 at 3:47 pm
    Thanks for the responses. Both helped in my understanding.
