Activity › Forums › Adobe After Effects Expressions › Getting ‘Separate XYZ POsition’ to work …
  • Getting ‘Separate XYZ POsition’ to work …
    Posted by Dan Cowles on July 30, 2006 at 6:28 am
    Hi —
    I’m trying to animate a layers z-position to an audio amplitude track, and in order to do so I’m using the ‘Separate XYZ Position’ animation preset on the layer I want to animate, then using the following expression on the Z POsition:
    thisComp.layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”)*10
    But, it’s not working. Any help?
    Mike Clasby replied 20 years, 1 month ago 2 Members · 4 Replies
  • Mike Clasby
    July 30, 2006 at 7:06 am
    I don’t know that preset, but try this:
    Type this expression into the expression box:
    [value[0],value[1],value[2]]
    That just says use the x,y,z
    Highlight the “value [2]” (the Z axis) and pickwhip to a Channel Slider for the Audio Amplitude Layer, to get:
    [value[0],value[1],thisComp.layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”)]
    If you wanted to Wiggle just the Z axis, try this:
    [value[0],value[1],wiggle(5,20)[2]]
  • Dan Cowles
    July 30, 2006 at 11:17 pm
    So, this works, almost … this is the same problem I was having before, my Z position value on my layer is changing correctly, and my X&Y values are remaining static, as they should … however, the layer itself is not moving. I must be doing something stupid/obvious, but can’t seem to figure it out.
    3D is enabled
    My expression is enabled
    I’m on the right layer …
    what else could it be?
  • Dan Cowles
    July 31, 2006 at 12:08 am
    Ack! Never mind, I figured it out … I had view set to ‘Front’, not ‘Active Camera’
  • Mike Clasby
    July 31, 2006 at 5:47 am
    I hate when that happens.
