Activity Forums Adobe After Effects Getting same error after ram previeuw
  • Getting same error after ram previeuw
    Posted by Anilio Sweet on July 31, 2011 at 12:56 pm
    Hi every one,
    I had a question, i am getting the same and same error from after effects after ram a previeuw.
    The message says:
    after effects error: All backgrounds processes have terminated
    So i googled it and i found a solving problem, someone suggest me to disable the multi proccesor, so i did, and that fixed te isseu, but i am wondering why??????
    I know that i have a minor laptob for working on my afx CS4 and i have 4 gb ram in it but it only want to use 2gb it says, and i have a dual core 1.6ghz labtop
    But if i turn out the Multi prosessor it says it only wil you 1.25 GB of ram and thats slowing thing real down ( it already was wit 2 gb but this is much more ) but the problem is solved but not on a way i wanted??
    Does someone has a another sollution??
    Todd Kopriva replied 15 years, 1 month ago 2 Members · 3 Replies
  • Todd Kopriva
    July 31, 2011 at 4:44 pm
    You don’t have enough RAM to use Render Multiple Frames Simultaneously multiprocessing.
    You also seem to have a 32-bit operating system, so even if you had more RAM, you wouldn’t be able to use it.
    Get more RAM and upgrade to a 64-bit operating system.
    See this page for information about memory and improving performance in After Effects.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Anilio Sweet
    July 31, 2011 at 5:34 pm
    Thanks Tod,
    Like always :):)
    I know but upgrading wouldnt help because laptop only sees max 4 gb.
    Puting a windows 64 bit on it wouldnt help, because there still wouldnt be a maximum of 4gb that i can put in the Laptob
    That is my problem, soo your help cant help me!!
  • Todd Kopriva
    July 31, 2011 at 5:53 pm
    Then just heed my first sentence. You can’t use Render Multiple Frames Simultaneously multiprocessing with that system.
