Activity › Forums › Apple Motion › Getting rid of Bounding Box Problems
  • Getting rid of Bounding Box Problems
    Posted by Mark Jackson on October 19, 2005 at 9:57 pm
    I’m trying to add a filter to a title I made in Motion. The problem is the rays of my effects is trapped in this bounding boxing. How do I get rid of the bounding box?
    Mark
    Doyle Rockwell replied 20 years, 11 months ago 2 Members · 1 Reply
  • Doyle Rockwell
    October 19, 2005 at 10:52 pm
    Hey Mark,
    if it’s Light Rays that you’re running, then try adjust the Expansion setting. If that doesn’t do the trick, nest the object in a layer, turn on Fixed Resolution for the layer (found in the Layer tab of the Inspector) and apply the filter to the layer. Basically, a pre-comp 🙂
    Good luck!
