Activity › Forums › Adobe After Effects › getting random black frames with Re:Flex Warp
Posted by Lloyd Alvarez on March 3, 2009 at 8:37 pmI am using Re;Flex Warp on a 32bit linear project and am getting random black frames, the entire comp goes black even though the effect is on layer 42 so you don’t see the layers above it either. Weird, I’ve used this plugin in 32bit linear projects before without any trouble. What’s weird is that it’s only on random single frames in the comp. Any ideas?
Pierre Jasmin replied 17 years, 7 months ago 2 Members · 7 Replies -
Pierre Jasmin
March 3, 2009 at 8:44 pm1) Could you be running out of memory?
— if so — if you are using Anti-Aliasing that is not 1×1, set “AA Method” to “Use less Memory”2) Is there any other plugin before it in the layer?
Pierre
Lloyd Alvarez
March 3, 2009 at 9:44 pmHey Pierre,
Update, it only renders the black frame when the resolution is set to half. So setting it to quarter or full res fixes it. Very weird. At the moment all the settings are at their default 1×1 and Faster, switching it Less Memory doesnt make any difference.
-Lloyd
Pierre Jasmin
March 3, 2009 at 10:00 pmI remember an AE bug that appeared in CS3 I think with odd size resolution (which your res divided by 2 might create)
Does it fix it to remove OpenGL preview in the display window?
Is this an adjustment layer?Pierre
Lloyd Alvarez
March 3, 2009 at 10:13 pmSo it turns out that at quarter res i also get black frames but at different point in the timeline. Am currently test rendering at full res. I have the Comp Fast Preview set to Adaptive Resolution or do you mean remove the opengl plugin all together?
Pierre Jasmin
March 3, 2009 at 10:22 pmNo don’t remove anything – if you use Adaptive Resolution, switch to OpenGL preview (couldn’t remember which one did it). Couldn’t remember which one was the issue and can’t look at my bug report until thursday. Hopefully it will render fine.
Is this an adjustment layer (I sort of remember it was related to that and an odd height amount, eg: 739 height image and it worked fine with 738 and 740)? If this is the case maybe precomping the footage and increasing comp height in precomp by one pixel would do it.
Pierre
Lloyd Alvarez
March 3, 2009 at 10:31 pmNope, not an adjustment layer. And I just found out that it’s doing it at full res as well. Gonna try turning openGL on now.
Pierre Jasmin
March 3, 2009 at 10:38 pmAny way you can send the AEP without media to techsupport at revisionfx .com so I can see your setup
and at the same time tell me which version of RE:Flex and AE.
Pierre
