Activity Forums Adobe After Effects Getting out of demo mode
  • Getting out of demo mode
    Posted by Bruce Rawlings on November 18, 2011 at 4:11 pm
    Just bought Twixtor and cannot get out of demo mode. I have entered the key they gave me as instructed but no dice. Cannot contact them as only email support. As usual up against the wire. Any ideas? Iam in CS5 Adobe AE
    Pierre Jasmin replied 14 years, 7 months ago 4 Members · 3 Replies
  • Peter Litwinowicz
    November 18, 2011 at 6:13 pm
    Glad we could help you offline and good to see ] you are up and running now.
    Pete
    RE:Vision Effects, Inc.
  • Andrew Varm
    February 27, 2012 at 2:32 pm
    I’m having the same issue having purchased a pro license, tried deleting all the plugin files I could find and re-installing, but still no joy. 🙁
  • Pierre Jasmin
    February 27, 2012 at 4:02 pm
    Are you using FCP?
    FCP (and a few other apps) do caching of already rendered frames across sessions, unless you change the value of a parameter you get the frame pre-rendered with an X, the solution is to change a value like put sensitivity to 70.1 instead of 70%
    If it’s not that, write to us with the product you use and the name under which it was registered (or email address) at techsupport at revisionfx dot com so we can see what is going on.
    Pierre
