Activity Forums Adobe After Effects Getting only the result of an “Add” Transfer mode of a highlight
  • Getting only the result of an “Add” Transfer mode of a highlight
    Posted by Ted Harisson on February 7, 2013 at 3:21 pm
    Say I have an image. On top of it there’s a layer with a highlight with an “Add” transfer mode.
    The “Add” makes the “light” merge beautifully with the image.
    I would like to use that merged highlight (without the image itself) with alpha so that it can be used on top of other images.
    (basically I am trying to fake the Add transfer mode, as it is pre-calculated)
    What is the best way to achieve that?
    Ted Harisson replied 13 years, 7 months ago 2 Members · 3 Replies
  • Chris Brett
    February 7, 2013 at 5:02 pm
    Hi Ted – either : –
    1 ) if the highlight does not move take frame into PS and paint everything else out with solid black
    2 ) if the highlight moves make an animating matte to remove unwanted areas
    …… then put result into separate layer and mix into bg plate…
    …….. and thats it !!!!! ——- chris —
  • Ted Harisson
    February 9, 2013 at 9:51 pm
    Thank you all for the replies. The reason for this is completely technical. The result of the animation has to be used on a real time application. Asking the computer to generate true real time add function would result in higher latency. I find it very challenging to find the right path to achieve this result.
    It basically means I need the highlight output only where it merged with the underlying image. Don’t use the image’s highlights.
  • Ted Harisson
    February 10, 2013 at 11:14 am
    I placed an example to what I am after.
    I guess I am after something as simple as the “Difference Matte” effect, but a more subtle approach of it. Meaning not having those harsh edges, and achieveing something more like a Luma Matte.
    I am attaching a short checkerboard example where the highlight that travels has an impact on the underlying layer, it actually feels like it is grabbinbg them like a space/time anomaly 🙂
    I’d like to preserve the difference between the layers and reuse it.
    CheckerExample
