Activity Forums Adobe After Effects Expressions Getting name for previous composition
  • Getting name for previous composition
    Posted by Kirill Komrakov on July 9, 2024 at 8:29 am
    Hi, I am trying to create an expression, where I am aligning one composition under another but with dynamically figuring out the name for the one, under which another is aligned. The general idea is to create a bullet list but without a need to constantly rewrite expression to fit compositions names.
    <font face=”inherit”>With the help of chatGPT </font>I’ve<font face=”inherit”> </font>managed<font face=”inherit”> to get this far, but </font>I<font face=”inherit”> am getting and </font>error<font face=”inherit”> “T01 Text aN does not exist” and </font>I<font face=”inherit”> can’t figure out, why AE don’t calculate right name. Would </font>appreciate some help. Thanks!
    // Get the current composition name
    var currentCompName = thisComp.name;
    // Extract the composition number
    var compNumber = parseInt(currentCompName.split(” “)[2]);
    // Calculate the previous composition number
    var prevCompNumber = compNumber – 1;
    // Format the previous composition name
    var prevCompName = “T01 Text ” + (“0” + prevCompNumber).slice(-2);
    // Get the text layers from the compositions
    var textLayer1 = comp(prevCompName).layer(1);
    var textLayer2 = thisComp.layer(1);
    // Get the position of the first text layer in the previous composition
    var aX = textLayer1.transform.position[0];
    var aY = textLayer1.transform.position[1];
    // Get the heights of both text layers
    var aH = textLayer1.sourceRectAtTime(time).height;
    var bH = textLayer2.sourceRectAtTime(time).height;
    // Get the spacing adjustment
    var adjustments = comp(“T01 Color & Adjustments”).layer(“Color & Adjustments”);
    var SpS = adjustments.effect(“Text Lines Spacing”)(“Slider”).value;
    // Calculate final x and y positions
    var x = aX;
    var y = aY + aH / 2 + SpS + bH / 2;
    [x, y];
    That is with assuming that all the compositions are named sequentially T01 Text 01, 02, 03
    Kirill Komrakov replied 2 years, 1 month ago 1 Member · 1 Reply
  • Kirill Komrakov
    July 10, 2024 at 6:48 am
    Ah, figured it out, the mistake was at first line to use thisComp. The right way would be thisLayer
