Activity › Forums › Panasonic Cameras › Getting live SD out of a Panny 900?
  • Getting live SD out of a Panny 900?
    Posted by Mark Suszko on January 30, 2009 at 5:10 pm
    Looking for suggestions on an inexpensive (ok, less expensive) way to get an SD signal out of the 900, we have a pair we’d like to use every once in a while in an SD live-switched situation.
    Our infrastructure for that demands a BNC cable with composite NTSC Standard Def on it. What kind of converter or adapter should I look at? The 900’s also came with Firestores on them, is there any other LIVE sd option possible somehow using those?
    The shooting situation is, the cams are 2 blocks away and feed back to our control room over dedicated fiber lines, currently those are set up to handle composite standard def NTSC. It would be too hard to change that setup for now, so I’m looking for ways to adapt to it as-is. My thinking is I’d rather have some simple, straight-forward adapter clip onto the cameras at the source end than try to feed SDI back thru the existing infrasturcture and convert at the control room end.
    Ernie Santella replied 17 years, 8 months ago 3 Members · 7 Replies
  • 7 Replies
  • Ernie Santella
    January 30, 2009 at 11:20 pm
    There are no converters needed. The HDX900 outputs NTSC Standard Def. You just have to select it in the menu. You can also choose if you want letterbox or crop.
    Ernie Santella
    Santella Productions Inc.
    http://www.santellaproductions.com
  • Mark Suszko
    January 30, 2009 at 11:25 pm
    That’s great news, guess I must RTFM again because I went thru a LOT of menus and couldn’t find it, assumed I could only get an SDI out.
  • Ernie Santella
    January 30, 2009 at 11:36 pm
    It’s a little tricky. First, you have use the back ‘VIDEO OUT’ BNC tap, not the side MONITOR tap. Then you have to put the side door panel switch into the ‘VBS’ setting.
    In the Main Menu (Hold down the front menu button for 4 seconds) under SYSTEM SETTINGS, select DOWNCON SETTING. There you get options for Letterbox, Crop or Squeeze, plus some control over detail and other settings for the down-conversion to NTSC.
    I used the NTSC down-convert with a SteadiCam as well as my old NTSC field monitor. That was before I bought an HD-SDI monitor. It worked great. This was one of the main reasons I bought the 900 over a Varicam.
    Hope that helps!
    Ernie Santella
  • Ethan Sigman
    February 3, 2009 at 3:00 pm
    Hi Ernie,
    can you explain the last part of your post…. what part of that workflow is not possible on a varicam?
    ethan
    http://www.EZSproductions.com
    http://www.productionmeeting.com/profile/EthanSigman
  • Ernie Santella
    February 3, 2009 at 4:03 pm
    The Varicam doesn’t have a built-in down-converter. You have to hang one of those AJA SDI-to-NTSC units on the side of your camera to get that. Kind of a pain to mount it and power it. Not to mention the expense also.
    The HDX900 has it built-in.
    Ernie Santella
  • Ethan Sigman
    February 4, 2009 at 12:22 pm
  • Ernie Santella
    February 4, 2009 at 4:29 pm
    I was referring to the F and H series tape-based Varicams. It’s great the new P2 versions have the built-in down conversion.
    Ernie Santella
